Ir para o conteúdo principal
Guias de reparo e suporte para a sétima geração das caminhonetes Ford F-Series. Os modelos incluem a F100 (descontinuada em 1983), F150, F250, F350, entre outras.
Why won't my truck shift?
My truck ran fine all throughout the day until I went home from work. It will move at low engine speed in 1st gear but won't put down power at high rpm and won't shift out of 1st gear without excessive engine rpm. I checked the fluid level and it was normal. There is also a burning smell. It has a 3 speed automatic with overdrive.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
the first thing is transmission fluid.
Low or no fluid could cause all those symptoms
Esta resposta foi útil?
Pontuação 0
1 comentário:
I checked the fluid, she was topped up.
por
Adicionar a sua resposta
Aidan Morris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 357
