Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
239 Perguntas Visualizar todos
iPhone SE 2020 battery replacement “non-genuine ” message
Hi, I want to change an original iPhone SE 2020 battery with an iFixit one. I’m wondering if I’d get a “non-genuine battery” message like the iPhone 11. Someone knows if I’ll get this message after a battery replacement? Thanks in advance!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
5 respostas
Pergunta mais útil
Yes you will get this warning on the SE 2020 model.
Esta resposta foi útil?
Pontuação 4
1 comentário:
is it a popup like "Touch ID is unavailable" or is it a persistent message that makes using the phone difficult?
is there a fix for this?
por
Yes, I get this message.
Pontuação 0
Hi There, you will not receive and error message normally only happens on XS and upwards.
Pontuação 0
1 comentário:
this comment doesn’t solve the problem!
por
100% correct i tried it and works
Pontuação 0
1 comentário:
i can’t change my phone to solve the problem! I bought the correct battery from ifixit … and have a permanent error message.
por
is the message permanent and a hard reset changed nothing? (that’s my experience)
Pontuação 0
Adicionar a sua resposta
Sergio Catania será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 61
Duração total: 1,940
