Ir para o conteúdo principal
Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
Apple watch SE LCD Polarized film replacement
When I fixed the screen of my apple watch SE, the polarized film was damaged
I ordered this film by Aliexpress!
I tried to install this, but it was not dark enough.
Should I use a special glue?
Or, should I add an another sheet like OCA film?
Please help me!
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
I have the same problem. I tried it with local but it was not better.
por
Do you have a solution?
por
Adicionar um comentário
1 resposta
Most of us just replace the entire display assembly as repairing the assembly is quite hard! Have you looked at just replacing the display assembly as outlined here? Apple Watch SE Screen Replacement.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes, I understand your answer!
I can fix apple watches on normal cases!
But it is the special case for me!
It was disassembled from lcd panel!
Please let me know how to install the polarized film!
por
@dotoli32 - Sorry I haven't done it so I can't tell you.
por
Adicionar a sua resposta
Hyunmyung será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 396
