Ir para o conteúdo principal
Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
77 Perguntas Visualizar todos
Pressure sensor replacement help
Hello I was replacing my defective battery however the pressure sensor cable that runs under the battery was torn. I see where it clips in on the right side but how do I attach the rest of the cable to the phone. Is the end a little solder pad? Can't find anything that addresses this.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It appears you're not alone in tearing the grip sensor cable when removing the battery. If you check out the Google Pixel 3 XL Teardown, you'll see they did the exact same thing when they were pulling the battery. It's too bad there's no repair guide for the 3 XL's grip sensors; maybe if you tackle the job you could document the process and contribute a guide!
The good news here is that replacement grip sensors are available on eBay for about $20 for a pair (left and right). I found two right off the bat using the search string "pixel 3 xl grip sensor".
Finally, to help things along, there does exist a guide on the Pixel 4 for replacing the grip sensor: Google Pixel 4 Left Grip Sensor Replacement. From that guide it appears the grip sensor is simply glued to the side of the housing; no soldering required.
The good news is it appears there isn't much, if any, further disassembly required to get to the grip sensor once the battery is out, unlike the Pixel 4 which seems to require a lot more part removal to get to it. I can't be sure, of course, but as best I can tell from the teardown photos it looks like the most you might need to do is to remove the speaker, for which there is a guide available.
Basically, if you read through the Pixel 4 grip sensor guide and follow along the last few steps, I think you may be in good shape with replacing yours.
Imagem de Google Pixel 3 XL
Guia
Nível de dificuldade:
Moderada
Imagem de Google Pixel 4 Left Grip Sensor
Guia
Moderada
1 - 3 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Fraz Kayani será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 131
