Is iPhone 6s plus battery the same as iPhone 6 plus battery
can I use an iPhone 6 plus battery in an iPhone 6s plus
Esta é uma boa pergunta?
Edit: You can use the battery from an iPhone 6 Plus in an iPhone 6s Plus, just keep in mind that the iPhone 6 Plus battery is thicker, which may affect the seal you get batween the display and the casing.
Esta resposta foi útil?
Can i use iphone 6s plus battery in iphone 6s? I really want to upgrade 2750 mah!
The batteries have different capacities but you can still use them as the 6plus 6s and 6s plus all use the same connector.
Yes, no dought you can use it. I used it so many times and no issues.
Últimas 24 horas: 8
Últimos 7 dias: 69
Últimos 30 dias: 206
Duração total: 4,540
