98 Grand Cherokee 4.0 running rough after tcase swap
I just swapped out my transfer case, had to change the rear output shaft as the new(used) one had no speedo sensor pick up. Changed the tcase initially without the shaft change. Engine light came on and ran rough with no speedo readings. Took it back out swapped the shaft and the speedo worked but the engine light stayed on and ran rough. Tried to unhook the battery to clear the code. No engine light but it still runs rough and almost stalls out sometimes. Ran perfectly before. It’s a 242j tcase. Any suggestions??? I have no code reader and can’t get to town to get one 🙄
Esta é uma boa pergunta?
