Ir para o conteúdo principal
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
20 Perguntas Visualizar todos
iMac 2007 24 inch changeable with the 20 inch?
Hi all,
So I have a dead iMac from 2007 (24 inches) and I'm getting a 20 inch one for free. Of course, the 24 inch screen is nicer, so can I put the 20 inch computer inside the 24 inch case and use the screen from the 24 inch?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Depending on the exact 20" model you might be in luck.
por
It's a 2007 model as well.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
As you can see here the logic boards are very similar!
iMac Intel 24" EMC 2134 Logic Board
iMac Intel 20" EMC 2210 Logic Board
The layout is the same, I'm suspecting its doable. I personally haven't done it but it would be a fun exercise to try!
Imagem de Replace a logic board compatible with the Model A1224 Early 2008 20" iMac. Fix processing issues like unexpected shutdowns, reboots or water damage.
Produto
$44.99
Imagem de Replace a logic board compatible with the Model A1225 Mid 2007 24" iMac. Fix processing issues like unexpected shutdowns, reboots or water damage.
Produto
$34.99
Esta resposta foi útil?
Pontuação 1
8 comentários:
@danj which power supply would I use? Or would I use both? I'm assuming that the 20 inch power supply is less than the 24, but not compatible? I'm sure there would be lots of space either way
por
@gaussymousy - You're just swapping the logic board correct? Thats all you should need to do.
por
@danj Yes but I still need a power supply right? Not sure if I can use the 24 inch imac's power supply in my 20 inch board.
por
@gaussymousy - I'm not sure I'm following you here. The 24" iMac power supply can be used.
por
@danj Ok so i've decided not to do the swap, but after I opened the 20 inch iMac, the cpu fan now goes on full blast. I've done all the resets, and checked the cables (Though for some reason if I power it up while the bezel is off, no fans) The fan goes to full about halfway through the apple logo. No fan control software is installed.
por
Exibir mais 3 comentários
First you need to discern why the 24" is not working. Probably the power supply. Take a look at the diagnostic LEDs on the logic board and tell us what you see.
Pontuação 0
2 comentários:
@mayer The optical drive makes the startup sound, but there are no other indications of life. As far as the LEDs go, the first three are on, but the last is not.
por
The 3 LED lights shows power supply and logic board are good. On this model your most likely failure is the video inverter.
por
Adicionar a sua resposta
Gaussy Mousy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 8
Duração total: 169
