Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
Cable torn during screen replacement
I tore the cables on the side of my replacement screen for the iPhone XS. Because only my glass is broken, and my screen otherwise works fine is it possible to use just the glass from the kit or will I need to buy a new kit?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Josh. Generally, there is no easy way to transfer the flex cables from screen to screen at home, so you will need to get a new replacement screen. This is probably best asked to the returns department of iFixit at support@ifixit.com (if you bought a screen kit through iFixit) to see if they can help you get a replacement.
Alex
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Josh Murphy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 51
