Taptic engine and Loudspeaker not working after housing replacement.
Hi everyone,
I've just completed a housing replacement on an iPhone XR and upon testing found that the taptic engine and the loudspeaker (Earpiece working fine) are not working. After rechecking connections and testing I found the same problem with the device. My immediate thought was that I'd damaged the charging port however, the device was still charging with that same charging port just fine.
Before I order the new charging port I just wanted to ask here to see if other people also believe the issue is the charging port.
Thank you,
Tom
Esta é uma boa pergunta?
