If I use AliExpress LCD, will there be a limit to the function?
I heard that repairing using aftermarket LCD causes problems with the MacBook's automatic brightness function and keyboard backlight. Is it true?
Esta é uma boa pergunta?
Well... It's not that simple! The source of the part is the key!
A new from the factory assembly (virgin) won't have had its camera calibrated for the TrueTone services so the camera and the brightness services won't work.
If you got a used display from what was a working system the calibration had been performed and is stored in the displays T-CON logic ROM and will work correctly with your system.
This issue is only a problem with the 2018 and newer MacBook Pro's that have TrueTone.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 42
