Ir para o conteúdo principal
Airport not being detected
I've tried multiple working airport extreme cards. None are detected. Ran hardware tests card is never detected. Verified that all cables are fine and connected. This is one of the boards that has the ram slot issue. Currently running 10.5.8. It's not detected in 10.4 either.
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
1 Resposta
Solução escolhida
It sounds like a logic board problem. Can you find one of the USB wifi units to try? If that corrects the problem you can swap out the card cage which may correct your problem. Ralph
Esta resposta foi útil?
Pontuação 3
3 comentários:
I tried a PCMCIA card, but not a usb. I'll pick up one and try that. I also posted a question about screen flickering, but I believe both of these were in the hope it was not a logic board issue.
por
If you tried a PCMCIA card and you have the flickering problem I would suspect a logic board problem. Ralph
por
I was hoping that wasn't it. But Logic Board replacement will be my next step. Thanks Ralph.
por
Adicionar a sua resposta
stacywebb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,992
