iPhone does not turn on after charging port replacement
Hi. I wanted to make the custom housing for my iPhone SE 2020. Originally it was SE RED PRODUCT, i have changed buttons flex and charging port (SE Black) but after completing the phone does not turn on. I tried wirelless charging and different plugs but there is no vibration or Apple logo show up.
Can you try to help me where should be the problem? Thank you
Esta é uma boa pergunta?
when you opened the phone before you did anything at all did u disconnect the battery because if you did disconnect the iPhone screen or something you may have fried the phone
por keith_themuscovyduck
Yes. The battery came of first and was plugged back last.
por nizanazo
was it pulgged in or anything like that
@keith_themuscovyduck no. All components were disconnected. The phone does not turn on after change of charging port. It was working before this assembly
por nizanazo
Did you ground yourself from ESD?
por teardown-er
Exibir mais 1 comentário
