Battery Power works, AC does not work
My Kenwood DPC-472 is consuming lots of AA batteries, so I thought I would try to run it via the AC adapter to save batteries.
I removed the batteries and plugged in the adapter to a 120V socket and into the AC plug on the unit. I inserted a disk, made sure the Hold switch was not switched on, and pressed Play. 00 flashed on the screen, and the unit turned off. I replaced the batteries, keeping the AC adapter plugged in, and got the same behavior.
When the AC adapter is plugged in, it appears the device defaults to the AC power.
I unplugged the AC adapter, and tried again, just on batteries again, and the CD played without issue.
Are there connections I should check to make sure the power is getting through?
Esta é uma boa pergunta?
