Ir para o conteúdo principal
The Sanyo VPC-X1200 is a 12.1 MP point-and-shoot style digital camera.
Camera comes on and says card is protected on display screen
Display says card is protected and can not take pics. How do I fix the card, so i can take pics and keep the SD card in the camera.
Esta é uma boa pergunta?
Pontuação 6
1 comentário
the insert card shows card protected
por
Adicionar um comentário
5 respostas
Solução escolhida
On the side of a SD card there is little groove/notch with a small plastic slider in it. That slider needs to be in the closest position it can be in the direction of the reader pins. Here is a video sowing you how to unlock the SD card. Here is a video showing you how to fix this problem if the little slider is broke or missing.
Esta resposta foi útil?
Pontuação 17
12 comentários:
Thank you so much. Instantly fixed my problem. : )
por
And thank you from me too :-)
por
Thank You !!!! I had no idea that was there..
por
Thank you , thank you , thank you :-)
por
valerie would like to thank you from the bottom of her heart. mijasval
por
Exibir mais 7 comentários
But there are also instances where the slide switch will not correct the problem. One example is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Pontuação 3
My vpc S885 Sanyo.....turns on....screen says CARD ERROR do I need a new card
Pontuação 0
I purchased a new card the same make and size recommended in the camera manual Sandisc SDHC 16GB. checked that the lock was off and still got the message protected card when switching the camera on.
With no card in all the camera functions work correctly
Camera Finepix S8200. The card works in everything else.
Any ideas please?
Pontuação 0
some times you can make sure the switch is closes to the brass pins and put a piece of scotch tape over the switch and the little cutout on the opposite side. make sure not to cover the shiny pins. this has worked on some cases. the card readers and adapters are not advanced enough for a SDHC card and newer windows operating systems won`t work on some of the newer cards because it do not support encryption.
Hope someone finds this helpful.
Happy New Year People
Pontuação 0
Adicionar a sua resposta
James será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 120
Ao todo: 37,886
