Water damaged phone, boots up but screen not working
The phone got drowned ca. 4 months ago. It didn't spend much time in the water, it was quickly pulled out.
When I charge it up and try to start it, it vibrates and I see the LED diode flickering. It seems like a screen problem to me.
Today, I opened it, and I barely saw any damage at first. I first replaced the old screen with a new one. Doesn't work. I then noticed that a few pins at the edge of the screen connector on the logic board are black. I think this might be the problem.
Not really sure what it is, I think those pins got shorted from the water. I have no idea how to clean it.
So far I tried scratching it off with 99% isopropylalcohol and a knife, but it just doesn't come off.
I have submerged it into iso and it's sitting there right now, however, I doubt it's gonna help.
Esta é uma boa pergunta?
from the sounds of it you might wanna check caps and resistors also.
can you see the pin in the connector? you may need to solder on a new connector at this point if you cant clean the pins to make a good contact.
por Logixal
