Ir para o conteúdo principal
Error showing "Unknown part" after battery replacement
After replacing the battery in my iPhone XS Max, an error message "Unknown Part" appeared in the settings.
The Settings>Battery>Battery Health cannot display battery percentage.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
3 respostas
Pergunta mais útil
This is normal behavior and is another way for Apple to discourage people from repairing their own devices. A warning is displayed in the introduction of the iFixit guide for battery replacement on this phone. If your phone is acting normally, you can safely ignore this warning.
Keep in mind that Apple continues to make moves like this that hurt the repairability of their products. Replacing the screen, battery, home button (if applicable), and/or front sensor assembly (on iPhones with Face ID) will trigger a message or cause some functions not to work on many iPhones and other Apple devices. Some tools, like the JC V1S, will restore the battery health functions but may not remove the "battery may not be genuine" message.
Serialization of parts is one of the things trying to be fixed by "Right to Repair" laws. You can learn more about Right to Repair under the Advocacy section on the footer of the iFixit website.
Esta resposta foi útil?
Pontuação 4
3 comentários:
Not only do you loose battery health - but now I can't download and install new OS updates. I'm stuck on 15.5 since Aug 2022 iPhone 11. Really upset with this.........
por
@Junior Hernandez That is a separate issue. I have never experienced lack of OS updates due to a battery issue. Have you tried updating via iTunes/Finder?
por
@Junior Hernandez i had the same problem until today. I gave my phone the OS Update with my computer.
por
There's a small board attached to the anode/cathode of the battery.
For a DIY repair, you'll need to transfer this board from the original to the new using a spot welder.
Then a programmer to reset the charge cycle of the battery.
Totally unrealistic/not cost effective for a one off at home, you would need a really good, reputable repair shop to carry this out.
Pontuação 3
2 comentários:
After the battery was replaced by a local Fix Shop i noticed the battery unknown message and later found out that the original battery BMS board needed to be install on the new battery. Really upset about this....... Apple thumbs down
por
Welding on a lithium battery has the risk of it blowing up in your face. I don’t think a repair shop will offer this any time soon
por
Unknown part battery
Pontuação 0
Adicionar a sua resposta
Hossam Zanaty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 160
Últimos 30 dias: 669
Duração total: 16,101
