Ir para o conteúdo principal
Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
MBP 16" 2021 Weird mainboard element which I found broken...
Hey! Can you tell what are these small black little things on MacBook Pro 16" 2021 mainboard? I wonder because I found one torn apart. I straightened it, however it is no longer fully soldered. Though it's broken my MBP still works.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It’s a isolation stud used to support the logic board from twisting about. similar to the one just above which is a spring version for EMI. This one is insulated.
You should be able to just glue it down so it is able to continue to work properly.
Esta resposta foi útil?
Pontuação 1
4 comentários:
So I don't have to be worried that something will stop working?
What kind of glue should I use?
Thanks for answers! :)
por
@szarik00 - You just don't want it floating around.
Some logic board epoxy should do.=
por
@danj You mean floating when using keyboard? Just trying to understand, because mainboard is screwed to the case.
por
@szarik00 - Allowed to break free
por
Adicionar a sua resposta
Adrian Jelonek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 125
