Ir para o conteúdo principal
A sexta geração do Subaru Legacy estreou no Chicago Auto Show de 2014 e entrou em produção para o ano modelo 2015.
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
EDWIN CHAN MENCIAS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 686
