Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Is it worth it to replace the isight cable?
Like the wires are exposed, there’s no fixing it.
The good news is I’ve got a isight cable replacement (I bought them for the wifi card purposes, at the time I didn’t know).
The bad news is I was completely unaware how difficult the process to replace the isight cable in the display screen was. You’d have to pull the display off, pull the screen apart, with heat guns and all that…..
Given I only use the front camera these days about 1% of the time, and it’s a Early 2011 Macbook Pro, and money’s not that much a factor and it’s a really old macbook.
Is it just overall more cost effective just to swap out a new/used display entirely?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
A full display will run between $60 to 160 USD depending on the condition.
Grade-B - 13” MacBook Pro Display Assembly, Apple P/N 661-5868
MacBook Pro 13" Unibody Early 2011 Display Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Calvin Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 55
