Io board ribbon turns off the computer… help…
My 13” Early 2015 MacBook Air stopped working. Not charging either. The symptom- it’ll turn on just fine when plugged in- and the io ribbon is disconnected. Once connected- the screen shuts off. The battery is also disconnected.
I’ve tried several power supplies, I replaced the io board, the ribbon, cleaned a bit of corrosion from the bottom of the Logic board using deoxit, still nothing works.
Esta é uma boa pergunta?
