Ir para o conteúdo principal
replacing TOP Front Rear Microphone (iPhone 6S)
Hi,
COVID19 side damage ! I used much alcohol+water solution to clean my iPhone 6S, and all of a sudden the Upper microphone of the iPhone 6S are dead. That is sure !
while putting iPhone on Video session (for example in WhatsApp) the other party can not hear any voice. In case of WhatsApp, there is no Voice which goes when any of the Front Camera or the Read Camera are selected. I am not sure if WhatsApp uses Front & Read UP/TOP microphones. I think WhatsApp uses only the TOP/UP Front microphone.
Anybody can help with below queries ?
Q1. if Top/Up FRONT Microphone of iPhone 6S can be replaced separately; Or it is attached with a set of Camera , sensors (all to be replaced together) ?
Q2. Same question as previous about Top/Up BACK Microphone (if exists) ?
Q3. Considering the answer given in above Q1 (or Q3), is it possible to take the Microphone (or the set of Microphone + camera + ... if required) of iPhone 7 or iPhone 5S and put in iPhone 6S ?
Q4. in case if any you know any guide of such replacement (My intention is to replace the least possible; as Microphone is only part damaged) ?
With thanks in advance.
Regards,
Azer
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
iPhone 6s Upper Component Cable Replacement For microphone and Substituição do alto-falante auricular do iPhone 6s for earpiece speaker. The microphone is kind of tricky especially if it is your first time and if you need a toolkit I would recommend Minnow Driver Kit only $15 USD.
Imagem de Minnow Driver Kit
Produto
Minnow Driver Kit
$14.95
Imagem de iPhone 6s Alto-falante auricular
Guia
Nível de dificuldade:
Moderada
10 - 25 minutes
Imagem de iPhone 6s Upper Component Cable
Guia
Difícil
1 - 3 hours
Esta resposta foi útil?
Pontuação 0
2 comentários:
I see "iPhone 6s Earpiece Speaker Replacement" talks about FRONT TOP speaker; but not mentioning if the FRONT TOP microphone is belonging to the same part or not; Meaning if it is a separated part, or belonging to a group of parts all together.
por
This is why I liked the upper component cable @azer8
por
Adicionar a sua resposta
Azer8 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 63
