Ir para o conteúdo principal
Looking to fix the right stick click on an Xbox One controller
I have a 1708 Xbox One controller that does not register the right stick click.
I've opened the controller up and looked at the clicker mechanism on the joystick and it seems to make contact just fine and push the button down. But it does not register on a button tester.
I've also installed a new joystick and still see the same issue. I'm assuming this is a board issue at this point? Not sure where to look on the board however.
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
It is probably a board issue.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Gotcha. Seeing if I can grab a bit more information about it. Is there something that can be replaced on the board or would it require a new board entirely?
por
@meattacos You could technically resolder a new part, but there is no way of knowing what part failed, therefore, the board should be replaced.
por
Adicionar a sua resposta
Francis Carow será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 227
