Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Ultrasonic cleaner solution for cleaning
Hi
I am needing to ultrasonic clean a MacBook board and I have ran out of my cleaner solution my question is are there any known safe household solutions for the cleaner to clean the board better
It would be greatly appreciated if someone could provide me with a solution
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Demineralized water is cheap, safe and does a great job at removing water based residues. After that, a good spray of IPA >90%, a toothbrush and some compressed air to remove all and everything in the end are usually enough to clean a board nicely. Branson is usually a big plus but not a must.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks
Will do:)
por
Adicionar a sua resposta
HelloMacOS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 121
