Left ear speaker stopped working, can I replace speaker only?
Everything else works on the left side, mute, volume charger. Is there anywhere I can get a replacement speaker only?
Esta é uma boa pergunta?
If you have the skills, (doesn’t require something extreme) you can actually open it up starting from the buns, then unsolder the 2 cables from the actual speaker (you will nead a heat gun and a solder gun for that), and heat all the way around it’s back just to get it warm enought for the glue to melt.
Then pull out the speaker you would like to replace, and solder the new one in place.
This shouldn’t take more than 30minutes.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 206
