Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
My phone overheats while power off and charging.
It overheats and lags while playing on medium graphics, the battery is on 87% health but if it heats while off and charging, could the battery need replacement? I use a 5 watt apple charger
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello Hadi,
you have a short circuit in the installation. If you can run the phone and it heats up a lot, it could mean that the problem is with the accessories. This will confirm the battery life. If the battery holds up for a short time and the current disappears quickly, there will be a confirmation and a yellow light should come on. The fault could be anywhere. If you don't deal with electronics, find a good repair shop - it should take about 20 minutes and not cost much. However, if the technician says that he can replace the battery and / or the screen - run away from this place. Probably the technician has no idea about the repair and learns from watching YT (as most of them - scientists :-)).
Anyway, I keep my fingers crossing,
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
haadi farouk será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 28
