Ir para o conteúdo principal
Hybrid laptop/tablet manufactured by Microsoft. Released November 2017.
38 Perguntas Visualizar todos
Are base battaries compatible between 1835 and 1832?
I own a SB2 13.5 model 1832 and the base battery doesn’t hold any charge. it won’t turn on without a charger.
The only replacement base battery I can find is for the 1835 model. would it work with the 1832 model?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Did you replace the battery with the 1835? and did it work?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You can check it by reading information about the wattage on the batteries. Compare the power between both the batteries. If there is the same watt and volt, then you can use it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mohammud Ali será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 464
