Ir para o conteúdo principal
Thread for questions about repair of the Casio PT-1 mini / portable keyboard, which I believe was originally released in 1985 (?)
Wondering why Casio PT-1 suddenly stopped working (won’t power on).
I have had mine since originally buying it new in the 80s. It worked fine until just recently when it stopped powering up. Unit is clean in very good condition so a bit baffled why it stopped working suddenly. I do not have AC adaptor and am using batteries. The battery compartment is also clean. I expect it is a small easily fixable issue so am wondering if anyone has experience with this / similar models and may have suggestions what to check and how to fix it. Thank you in advance to anyone who may be able to help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I have the exact same problem with my Casio PT-100 I got at goodwill. Took it apart and found that the diode is completely broken off and missing. I am guessing the diode is your issue as well.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ThomasF será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 497
