Ir para o conteúdo principal
Seagate external HDD Drive 8TB Model#: SRD0PV1 Models of differing size likely have the same casing.
Seagate backup plus desktop drive 4tb turns on and off.
STDT4000100 Seagate backup plus desktop drive 4tb turns on and off while connected to my computer.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Probably a power supply issue. Just make sure the (12V 1.5A look on the label on yours) polarity is correct. You will usually see a little diagram with three cirlces. The first will have either a + or a - symbol with a line to the edge. The third will be like the first but with the other symbol and a line going to the black dot in the centre. If it is not the power adapter then the drive enclosure may be the problem.
Esta resposta foi útil?
Pontuação 3
2 comentários:
It was the USB power-saving feature.
por
@nytryder26
There you go Ben, a simple solution. Good one!
por
Adicionar a sua resposta
NR26 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 714
