Ir para o conteúdo principal
Manuais de reparo para o HP Pavilion identificado pelo número de modelo: 15-d017cl.
Can replace this laptop's internal wireless card?
Having difficult time learning if the internal wireless card can be replaced or is it attached to the motherboard? I’ve tried 2 different USB wireless adapters but one they’re running, when I turn laptop off and back on—no Internet. Are ports too old to handle them? Thanks for any help you can offer.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
First of all have you checked to see if the wireless adapter is showing up in the Device Manager in Windows Control Panel. If it is there but has a yellow exclamation mark then it is possible the driver is corrupted. Uninstall it and let reboot and let Windows automatically reinstall the driver.
To answer your question:
Yes it can be replaced and is not soldered to the motherboard. Gently pry off the black antenna connecting wire, unscrew mounting screw and slide card out of socket.
Here are the disassemble instructions:
Substituição da placa-mãe do HP Pavilion 15-d017cl
The wireless card in circled in red in the first photo.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank you! That’s a BIG help. Have a couple deadlines this week so may need to continue limping along til the weekend. But at least you’ve given me one more option to try! Your quick and knowledgeable response is much appreciated.
por
Oh, and yes, I did go to Device Mgr and first tried uninstall/install ... no luck. Thanks!
por
Adicionar a sua resposta
LinDee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 630
