Ir para o conteúdo principal
Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
190 Perguntas Visualizar todos
MacBook not entering internet recovery - 2100f
Hi
I have a Macbook Pro A1990 emc 3215 mid 2018 15" model. It has had its OS removed so I need to reinstall MacOS. No matter what keys I press it always boots to internet recovery (I've tried to do PRAM clear, CMD+R for recovery mode, Option key for boot options, D for diagnostics). When I enter my WIFI password it accepts it, starts loading into internet recovery but after around 30-60mins it fails showing error code 2100F. I have tried a power drain by disconnecting the battery and mais power but that has not changed anything. Does anyone have any ideas what is going on?
Thanks
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Is this a used system? I fear you have a iCloud locked system.
por
Yeah it is used, it could be locked but I have had locked ones before and I've never seen them behave like this
por
@christophe30013 Were you able to resolve this? I am also going through the same issue.? Any pointers are appreciated.
por
Adicionar um comentário
3 respostas
Solução escolhida
@bagomac
Yes managed to resolve the issue in the end. I have had a good 10- 20 more devices doing the same thing and this has worked on all of them. It seems to me that the T2 security chip has become corrupted somehow, possibly during an update. You can refresh the firmware from another mac using this guide though and after that it seems to perform as expected.
https://support.apple.com/en-hk/guide/ap...
Hope this helps!
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Time to visit an Apple Store to see if they can help you.
Pontuação 1
Hi
Have you tried installing macOS using another Mac onto an external hard drive then booting into it and installing with a installer from within the OS
That’s how I basically force a install on a stubborn computer
but if that doesn’t work I would do as @danj has said previously and take it to the apple store!
Hopefully this helps
Pontuação 1
Adicionar a sua resposta
Christopher Summers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 45
Últimos 30 dias: 269
Duração total: 4,380
