Ir para o conteúdo principal
Guias de reparo e suporte para andadores médicos. Um andador ou estrutura de apoio é uma ferramenta de mobilidade usada por pessoas com deficiência que precisam de apoio adicional para manter o equilíbrio ou a estabilidade ao caminhar.
My brake wires are frayed by my handle how can I fix it
Brake wires are coming out at the handle can that be fixed
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
I would recommend replacing the brake wire that is frayed. If you are familiar with working on bicycles or just handy in general, this should be an easy fix.
Otherwise, I would recommend taking it to a local bike shop (bike brakes have the same mechanism) or a local shop that can repair medical devices and walkers.
If you choose the DIY option, here is a great guide that outlines how to complete this repair for a walker: Substituição do cabo de freio do andador.
Esta resposta foi útil?
Pontuação 2
2 comentários:
How to fix my handle cable brake on my walker
por Compartilhar
Can you tell me how to do the fix or show a picture how to fix it
por Compartilhar
Hi delsea,
Your walker uses the same brake mechanism as the hand brakes on bicycles, so replacing the brake cable is exactly the same procedure. You just need a replacement cable to start with; as @fa1conx has suggested, a bicycle shop should have what you need. If there aren't any shops nearby, it's likely a well-stocked sports shop or hardware store may carry the cable.
Here's a wikiHow article on bicycle brakes that should give you everything you need to know about your walker's brakes.
6 Ways to Fix Brakes on a Bike - wikiHow
Pontuação 1
Adicionar a sua resposta
delsea será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 2,424
