After coffee spill, keyboard acts as if shift key is pressed
Hey all,
This is my first time perusing this site…. Thanks all for the great community and how to guides. Wondering if anyone has any ideas on how to solve a recent problem of mine.
I accidentally spilled a cup of coffee over my Macbook’s keyboard. After a quick facepalm, I turned the laptop upside down to let the coffee drain out and air out for a few minutes. Later that day I tried using it. There didn’t seem to be any problems, except that all of my keypresses acted as if the shift key was depressed (capital letters, special chars instead of numbers, etc). I confirmed this by opening the keyboard viewer. It showed both the left and right shift keys as being depressed constantly.
I then made the mistake of trying to restart and clear the NVRAM. (I did, but that didn’t seem to help). I am now unable to log in since I can only type in caps, even when using an external usb keyboard. The odd thing is that, if I boot into the OS reinstall mode where I can open a Safari browser, I can type in lower case via the external keyboard. But, since I can’t login at the regular login screen, I suspect that somehow at that point things work differently and the shift key from the built in keyboard *is* being applied to the key presses from the external keyboard. (A counterpoint to that though is that I am only able to use the startup key combos from the external keyboard, which implies that the shift key is not being applied to the external keyboard in that context. Odd.)
Following an ifixit guide I pried off the two shift keys. I don’t see any dirt or grime.
My immediate concern is to be able to login using the external keyboard. Any ideas on how to do that?
Second question is if there is a way to salvage the built in keyboard or if I need to replace it.
Thanks!
Esta é uma boa pergunta?
