Ir para o conteúdo principal
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
broken keyboard ribbon and trackpad
I was trying to install windows 10 on my Chromebook since it didn’t have much use and it was so longer receiving updates so i thought it would be a good use. So i watched a tutorial and i had to open the laptop because i needed to unscrew the wright safety screw but while doing so the white ribbon came off and i think it was damaged i put the wire back in to the keyboard ribbon when i booted it back up the keys wouldn’t work or the trackpad i tried everything but nothing worked. I hope someone can help me.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
i only need the full step to install window on all version of chromebook after disabling write protect screw.
how do we identify write protect screw in all chromebook
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
shush será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 56
