How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
Esta é uma boa pergunta?
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
Esta resposta foi útil?
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 216
6 comentários
Do you have a hot air station?
por Andrew S
nope
i guess i'll just replace the motherboard
por notnice -96
i'll need to back it all up
por notnice -96
@andrewsawesome what if i did?
por notnice -96
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
por Andrew S
Exibir mais 1 comentário
