Ir para o conteúdo principal
The Acer Aspire R11 R3-131T-C1Z511 is an 11 x 6 inch, lightweight (1.5 kg (3.48 lbs) convertible notebook laptop that is part of the R11 series, manufactured by Acer. Colored in light blue or white, the laptop has a standard keyboard, HD touchscreen display, and a large touchpad.
6 Perguntas Visualizar todos
BIOS password reset on laptop
Hello, I have an Acer Aspire R11 R3 131T (blue) that has a bios password locked on it that has been forgotten. I need to reset the Bios so i can do a clean install of windows through the F10 Menu thats is disabled behind the password.
What I have done:
Removed battery and cmos battery for 1 hour
Used a BIOS code generator to access the bios through the given key (i can access the bios, but cannot change any settings besides date and time, when i enter the code in the supervisor password, it returns as incorrect and halts the system)
Attempted to short the pins to reset the cmos. G108 on the motherboard documentation.
Each time the same result, pressing F2 results in a password being asked, which i can bypass through a code generator, but cannot disable the supervisor password. I meed to reset the bios because the computer is useless in the current state. Any help would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Downloaded a BIOS update from acer and installed it, bios wiped, password gone, the computer is back and everything is great.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Pls, help me I am facing the same issue.
por
Adicionar a sua resposta
Michael Shepard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 1,015
