Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Home Button Spacer Needed
I am working on a screen replacement on an iPad 5 and need a new home button spacer. It’s the little ring that is attached to the digitizer. I found a couple on eBay but wanted to see if there is a universal one on here or anyone know where I can track one down.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
make yourself - find a plastic piece of the correct width and cut it out. Ultimately, you can glue the correct number of Kapton slices together and cut with a scalpel.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jmcdonald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 96
