Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
iPhone keeps rebooting after replacing battery
After replacing my 3gs battery the phone keeps rebooting every few minnuts, I replaced the old battery and the phone works fine, after serthing for the solution,
it apers to be one of three things,
1) a defetive battery.
2) the rong battery.
3) compatibilety issue between te latest OS and non OEM batterys "OEM batterys aperintley have an ID chip that the OS looks for"
The old battery is APN:616-0431 VPN:GB-S10-374270-0100
The New battery is APN:616-0435 VPN:LIS1416APPC.
can eney one tell if I have the right replacment battery or not?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
It can be hit and miss with 3GS battery replacement. Buy another from another vendor. That apn should be fine but... Read feedback before buying off eBay etc
por
You Have the right one, probably just a bad battery.
por
I have exactly the same problem!! replaced the battery in my old 3G and the thing keeps rebooting.
por
I have the same problem.
I have same APNs and VPNs as you. Please post your solution if you have found any.
por
Adicionar um comentário
1 resposta
Solução escolhida
just receved an email from Ifixit they think its a bad battery and there sending me a new one. thanks to Ifixit and every one here fore the help.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,038
