Ir para o conteúdo principal
Mate 20 from Huawei announced in October 2018 in London. Global model HMA-L29 is available with 4/6 GB RAM and 64/128 GB storage. Triple camera setup, 4200mAh battery, and rear-mounted fingerprint sensor.
Is it possible to replace the charging port?
Is it possible to replace the charging port of my phone since I have problems charging my phone. It has problems with some USB-C cables and I have to tuck them in a very special way, also fast charging doesn't work anymore.
Where can I find replacement parts (and maybe a guide)?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It is possible, but unless you have some experience soldering tiny wires, you may do more damage than good. Lots of shops replace charge ports for alot less than the cost of your phone. If you still want to DIY I’d practice on something else first. You’ll need some tools, so the cost may be no less than just going to a shop unless you already have everything.
As for parts, I usually just buy on Amazon or eBay, but a google search will find plenty of sellers, depending on where you live. partsforrepair.com is a good site for parts too.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Theo Thiedig será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Ao todo: 359
