iFixit Battery not charging
After replacing my old battery with a new iFixIt Battery the new battery started to charge, but after 5-10mins the charging stops. While charging works the estimate on remaining charging time is over 10hrs
I thought my old old charger was defective, too and not able to fire up the new battery, so I got a new 85W Apple Original MagSafe 2 charger. The new charger is still not helping with the battery.
I got the battery with 23% and was able to load it to 51% over the course of 5 days.
I tried multiple SMC and PRAM resets, but as much as I can tell, these resets were not effective. Changes to the battery settings were not reset after SMC reset. The MagSafe LED did change from orange to green after the SMC, but all other settings (loudness, keyboard backlight, …) didn’t change/reset after SMC or PRAM reset.
I also cleaned the MagSafe Charger Port, the pins look clean to me.
Please find Coconut Battery Screenshot and System Report attached.
When charging Battery Health indicates a 3.5W charging. See 2nd screenshot.
Edit:
[strike]I feel the battery keeps on charging while I have apps running that are “using significant energy” per the MacOs Battery indicator in the menubar.[/strike] This has not proven to be correct. Instead the more I’m using the MacBook the longer the charging will go on for. While active use of my MB, especially using the TrackPad, the charging will continue. While I was typing this text, the Watts dropped to 0, before I was browsing the web using Safari and the charge continued.
I also ran the OS Diagnostic StartUp with no issues reported.
Standing by for further information! Any help highly appreciated!
Edit 2:
I also deleted the NVRAM through Terminal nvram -c
Esta é uma boa pergunta?
