iPhone 12 Pro Max cracked
My iPhone pro max has a battery problem which keeps turns of every minute and front screen and back has a crack ?
Esta é uma boa pergunta?
Did you already replaced the battery ? If not, your battery is probably end-of-life. You can replace it following this guide : iPhone 12 Pro Max Battery Replacement
Regarding the crack in the front screen, the repair guide is here : iPhone 12 Pro Max Screen Replacement
Regarding the crack in the back, I would suggest to simply add a case for your phone (this will also protect it from further cracks. I would suggest to also add a screen protector (simply search for it on your prefer search engine / online retailer).
Hope this helps.
Guia
Nível de dificuldade:
Moderado
1 - 2 hours
Guia
Moderado
1 - 2 hours
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 1,030
