My airpods isnt charging
The red charging light on the airpods case isnt showing and neither the airpods are charging
Esta é uma boa pergunta?
From what I can guess is that the battery or the charging port in the case could be defective. You could try using the wireless charging and see if the device charges. Unfortunately their isn’t an easy way to repair these. I do encourage that if the device is still under warranty that you bring it back to the seller and report the issue.
Esta resposta foi útil?
I would also see if the port has any debris in the actual port itself and try cleaning it out.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 103
2 comentários
Hello, does the light change when you plug the case in?
por Jacob Mehnert
No there’s no light when i plug in the charger
por Namir Shah
