Why does my A30 just keep switching on and off to the Samsung logo
Why is my A30 stuck in a loop.
Esta é uma boa pergunta?
could be a bad battery or one with low charge. It may be shutting down after it tests the battery charge and finds it is below the shutoff level.
Esta resposta foi útil?
Not the battery, does with full charge. Thank you for your help.
Why does my A30 just keep switching on and off to the Samsung?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 573
Hello.
Have you tried to force your phone to reboot..?
I think you need to hold the power down for 10 seconds or something.
When its off you need to wait a few seconds and then hold the power button again until it wakes up.
I'm not sure if this is a quick fix hack or is there some longer / better solution
por Stephen Gilsenan
I've tried that. Stays stuck in its loop. I've tried the boot menu. Stays stuck... But thank you.
por jenniferpinnell1973
Ok.. I did find something that was related to - Samsung Galaxy A30 keeps restarting, Freezing Problem and Closed Unexpectedly | How to Fix? -
if you search that you may find a suitable answer
@eureka is this what you were relating to :https://hrdreset.com/samsung-galaxy-a30-... ?
It is okay to add links into your comment or even to your answer. If iRobot "bites" again let us know :-)
por oldturkey03
