thin horizontal lines on screen
When you turn on the laptop, a thin horizontal black line appears that occupies the entire screen. Curiously, they are removed by lowering the screen and leaving it approximately 5 fingers.
Update (01/16/2022)
Esta é uma boa pergunta?
Can you post some pics and a short vid so we can get an idea what you mean by five fingers. Adicionar imagens a uma pergunta já existente
por Dan
Even I’m facing the same problem..
por P k
how did you solve the problem? I have it too
por stardo baba
@stardobaba - If moving the display alters the condition that points to a bad connection between the T-CON board and the LCD panel. This sadly requires a new display assembly.
A common cause is getting something caught between the uppercase and the display along the back edge like a paper clip or pen this in turn cracks the chin plate which covers the cables. As the space is so little the glass shards of the chin plate cuts the ribbon cables. Some clip on case covers can also do this too.
por Dan
