Ir para o conteúdo principal
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
Screen Replacement Compatability between models
I recently broke my screen, and I was looking for replacement parts online, but I do not know which models would be compatible for replacement. My MacBook is a 2020 MacBook Pro 13” (A2251) with touch bar.
I found a really good deal on an A1708 model screen, however I have seen a ton of things saying a lot of the non-touchbar model parts are incompatible with touchbar models. Is this the case for the screen?
If so, what models ARE compatible?
Bonus question: where is a good place to find parts such as screens?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Apple uses a few different assemblies depending on the model series so you can’t just willy-nilly mix things based on price. The A1708 models are very different!
Both the 2020 Intel models (two TB port & four TB port systems) use the same part:
  • 13” MacBook Pro Display Assembly - Space Grey, Apple P/N 661-15732
  • 13” MacBook Pro Display Assembly - Silver, Apple P/N 661-15733
Presently they are out of stock at the sources I reference.
If you need to get going quickly I would find my way to an Apple Store as being the quickest, but it will be pricey!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Wyatt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 73
Ao todo: 452
