Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Transparent screen not quite flush?
The iPhone 4S transparent back doesn't sit quite flush w/ Verizon iPhone 4S. It appears to be off by a fraction of a millimeter, enough so that the flash isn't centered with the hole.
I would need calipers to measure the minute distance. The best indication is that the camera and flash holes aren't perfectly dead-centered over the elements.
I have removed/reattempted several times, verified that there aren't any manufacturing boogers or burrs on the catch-ears.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Very common problem with conversion kits. Take the screws from the back plate out. Take the phone in your hand and push the the side that is hanging over againt a table or something until everything is flush like you like. Dont worry you wont hurt the phone.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
eric será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 10
Duração total: 725
