Why is my i7 not picking anything up
My roomba goes around like normal but does not vacuum anything up
Esta é uma boa pergunta?
Hello.
The Ruumba, like all things mechanical needs a bit of maintenance every now and then to keep it working the way it should - for longer. Try checking these maintenance items to see if everything is in check
Esta resposta foi útil?
In particular, this roomba version depends heavily on the roller due to its terrible fan motor. The rollers are designed to wear away so that they do not wear away your floors and carpet. This means you have to regularly replace them. A good sign that they need to be replaced is the Roomba does a terrible job at picking stuff up
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 48
Duração total: 364
