Ir para o conteúdo principal
Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
150 Perguntas Visualizar todos
My MacBook battery stuck on 1%. And high kernal_task
My macbook battery is stuck on 1%. While using mac, it is very slow. I checked cpu usage, the culprit is kernal_task. Fan speed is also very high. Is Battery failure causing high kernal_task cpu usage? Or is there any other failure in my hardware apart from battery?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
Solução escolhida
This is almost certainly a failed battery. If a MacBook cannot get sensor data from the battery (or any other sensor in the device), it assumes the worst. It throttles the CPU and ramps up the fan to fight the searing temps it assumes whatever component is experiencing, even if the issue is just a sensor has died, or cannot communicate with the SMC/T2.
I have seen this issue many times on various Macs. I would run Apple diagnostics (Press and hold D key when you’re powering the unit on from a powered off state) and see if it throws any errors.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
34thdj fdbgr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 151
