Ir para o conteúdo principal
Informações de reparo e desmontagem para o smartphone Android topo de linha da Samsung, o S20 Ultra, lançado em março de 2020.
S20 ultra won't charge past
I’ve tried a new charge port, ribbon connectors, wireless coil, and a new battery. Its says that the battery a 0% until I plug it in where it shows a charging symbol. From there I have to press volume down and power to turn it on. Then once its on, it won’t charge past 50%. I wish I knew what is all of the components is connected to charging so I could brainstorm on the issue.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If it used to be a demo or something check to see is retail is still on, if so try to disable it, then it should work fine, if it was not if it has most of it's storage taken up by ‘system’ then factory reset it, otherwise you might have to put in a new battery or try powering it off and charging it.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Lemme know if it any of these work by commenting
por
I’ve already put a new battery in it and factory reset it.
por
Have you been able to resolve it and how did you do it?
I'm having similar problems. I press volume down and power and then plug it to power it on and it stays at 50% and doesn't charge and drains off when I keep using it. I have changed battery and changed new charging port/panel the same thing happens. It doesn't charge and stays stuck at 50%. What do I do?
por
Adicionar a sua resposta
Terence Mallett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 546
