Ir para o conteúdo principal
Sleep/Power Button and Volume Controls won't work after a repair
my ipod needed a new battery, so i took it to the "Fix-a-Phone" in my local shopping mall, after the phone repair "Specialists" replaced the battery, i tested all my buttons, and the Volume Controls as well as the Sleep/Power button were non-responsive, i asked the guy who fixed it about it and he said he couldn't help me because he didn't even go NEAR the buttons, i called a BS on that and now i don't know what tool(s) to fix this iPod P.S. I NEED TO HAVE IT FIXED BY CHRISTMAS 2011, HELP!!!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
He severed the flexicable that is right next to the battery. Talk to his manager and demand it be repaired by a real certified tech instead if some kid at the mall kiosk. If that gets you no where call the techs at Atlanta Cell Tech at 404-831-0399 and ask them about scheduling a repair.
Esta resposta foi útil?
Pontuação 2
I myself just completed the same task that you've asked about and its not a job for the faint hearted. If you want to give it a go you'll need a new volume/on-off flex about £6 off ebay. You will also need the plastic tools to open your ipod complete with the sucker, a heat gun, a soldering iron, solder, solder mop and a very small philips screwdriver. I would recommend de-soldering the battery before going any further to help prevent you shorting your ipod. After that you'll need to completely strip the ipod down (i.e circuit board, battery and both camera's out).
Pontuação 1
1 comentário:
P.S.
Use the ipod teardown tutorial thats on this site to help you with taking it apart and re-assemble. Hope this helps.
por
sell it on ebay...they are all broken on there ..
Pontuação 0
1 comentário:
it's really not a good answer. Anything else you might want to add to it, something that is more productive?
por
Oh oops, sorry everyone I just remembered tha it isn't an iPod g4 it's an iPod g3, sorry I wasn't thinking correctly when I asked this question, can someone tell me the process for an iPod g3 for this same problem
Pontuação 0
Adicionar a sua resposta
Andrew Carter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 2,239
