Ir para o conteúdo principal
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Perguntas Visualizar todos
How to secure front rubber impact strip to it's bumper?
My 1985 300D front rubber trim is loosening from it’s bumper. I tried to get the clips back into place and slide the impact strip into place. Unfortunately, it will not remain snug.
Advice and directions to fix would be most appreciated.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like your not getting the clip far enough onto the rubber backing . A near impossible task on dry rubber. If you were to spray the rubber with a spray lubricant like liquid wrench or wd40 you’ll find you can push the clip on further and then when you assemble your fit will be tighter. Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Scott Henson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 105
